Transfer case Prob.
Zack
Evans Georgia
I have been searching but have had no luck finding info... I believe my transfer case is bad on my deuce. I went to pick it up this last weekend, while working on the brakes we noticed that when the front drive shaft is turned the case would make a clank noise. So we removed the front shaft and i hit the road. When the truck was under power there is no noise but when i let off the throttle i would get noise, even with the clutch in and the truck in neutral still noise untill it would stop rolling. Sandcobra and i believe it is a bad transfer case. So what i am asking is does anyone have experience with rebuilding or repairing them.. Or possibly have an extra transfer case for sale.
Floridianson
2,498
Interlachen Fl.
Don't know if it related but I had to change mine out. It would ingage it's self. I have not pull it apart to check for shure but I'm thinking the retainer bolt came lose on the shifting fork for front engagement.
gringeltaube
Staff Member
2,454
Montevideo/Uruguay
At least your TC is not jumping out of gear, which normally is a first sign of serious wear/high mileage.
What kind of noise? If gear whine it could be just bearings gone bad.
I would go step by step, checking everything else around the TC first before deciding to repair/replace the whole unit.
Have you checked input- and rear output shafts for end play, axial/radial? Have you run the TC in NEUTRAL with the truck standing still, to evaluate noise?
G.
