Transfer case PTO installation question
Tomtsled
Kingston, New York
I can't see how all the bolts are going to go back in those bolt holes. On a couple of them it doesn't even look like there's enough room to put the bolt in to start it, let alone room to twist a wrench around to tighten them up. Any tips on the trick to getting them all in?
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
westfolk said:
Make sure you have the correct gasket for it, or at least the right thickness of gasket in there. If you use just Permatex or something as such......your tranny WILL NOT like it.
I don't see the problem, I would say NO gasket, just ANY good sealant works fine, if we are talking about the TC PTO. :?
And yes, you'll need at least some studs to correctly mount it.
1,824
The transfer case PTOs are out there. They can be costly if you shop at the wrong place. It will fit on any M35A2 transfer case if that is what you were asking.
yorkgulch2
Idaho Springs, CO
Kenny
Kenny, Thats what I was asking. I haven't found a cheap one yet.
Tomtsled
Kingston, New York
Gringeltaube, #1 is a stud, but I'm pretty sure # 4 is a bolt. How many studs will I need, and how many bolts? The transfer case did just have the cover over it. Also, I called Memphis Equipment about the studs and the guy in parts didn't know what I was talking about. Does anybody know where I can get this stuff?
1,824
BFR still has the one I sold him. He also has the studs. Perhaps he can get you the length and thread pitch so that you can source them locally. The PTO originally had studs all the way around.
pa.rich
Call Memphis back and ask for Roy - he can take care of it for you. I recieved an incomplete order from them and had payed in full. Ended up holding payment and roy sent the balance and an apology. They can help you, but you need the right person in parts. Btw, they supplied studs for mine off the tranny on the five tonner.
country
394
Feasterville, Pennsylvania
the studs are standard at any truck parts place. they are standard thread on one end and fine thread on the other
don't forget the coupling that goes in between the PTO and the transfer. It looks like a lovejoy style coupling, but it is made of steel
we have a few of these PTO's in stock, I think 2 new ones possibly and a few used
Also have PTO accessory drives that mount on the back of the PTO to run pumps, etc, they run one direction and one speed
Dave
www.easternsurplus.net
