transfer case pto output
BFR
Rocket Surgeon
2,330
42
North Georgia
Can I use tooth count on roller chain sprockets to determine reduction (like teeth in gear sets)?
If so check my logic…
I can’t use a drive shaft w/o moving my air tanks and I have no desire to move them, so I plan to use ANSI 60 roller chain & sprockets instead. I want to keep the chain speed down and since I can use engine RPM combined with transmission to determine PTO speed, here is what I have come up with.
2nd gear @ 1250RPM (actually 1251 RPM) will result transfer PTO output shaft spinning at 450RPM
26 tooth sprocket on the pto (spinning@ 450RM connected to 13 tooth sprocket on the pump will result in the pump’s input shaft turning at 900RPM
or
2nd gear at 1400RPM (actually 1390) ->500RPM->1000RPM
or
2nd gear at 1550RPM (actually 1530) ->550RPM->1100RPM
BFR
Rocket Surgeon
2,330
42
North Georgia
I got the sprocket installed on the pto using a quickdisconnect bushing and matching sprocket. I put it together the other way first (the teeth on the sprocket were near the flange end), but the crossmember and the sprocket made contact preventing the flange from sliding on to the pto output shaft.
