eldgenb
- 1
- 16
- Spokane WA
I have a 816 with no wrecker body, it has the "on all the time" transfer case pto and I want to hook hydraulics to it, do they make some sort of on/off shaft coupler to disengage the pump or should I just let it run and put a relief valve in line so that it is not holding pressure? I could not find a good solution other than doing something different all together and I would like to use this pto since I still have it.
thanks in advance.
thanks in advance.
