Transmission fluid overflowing out of dipstick
Jerrysri
After 15 mins of hard driving in sand on the beach my 1989 m998 the transmission fluid overflowed out of the dipstick. Thoughts ?
eaw46
If it is pouring out you have big issues if it is just leaking then I would check the transmission vent tube if it is blocked you can build up pressure and some fluid can come out the dipstick but not much. Good luck. Eddy
Jerrysri
Only a couple of ounces came out the dipstick when it was hot and working hard. I let it cool and it was fine. I will check the vent, thank you !
