Transmission install
Bill in pa
40
homer city pa
Is there any tips and secret info to installing a m35 trans mission?
I have it up in close.
But just can't seam to get the pilot bearing and splines lined up.
Thanks.
M35A2-AZ
380
Tonopah, AZ
Did you use a clutch alignment tool? Also may help to cut the heads off some long bolts and use them to help align the transmission.
V8srfun
538
Altoona pa
when installing a transmission sometimes you need to get aggressive with the push and wiggle. I have never seen a manual transmission just slide in to place without a little persuasion.
fpchief
220
South Alabama
If the clutch is aligned, it is just a matter of as V8srfun said....push and wiggle! I did mine 100% by myself and once aligned, I got under it and pushed up with my knees and feet...all of a sudden it just slammed in place. The flywheel was harder I think.
MG2936
60
Lapeer, Michigan
What I do is jack up the back of the truck utill the drive line is paralled with the ground. (about 6 inches on the rear axle) If you are using a trans. jack or a chainfall it slides in much easier.
DB556
129
Ambridge, Pa
I pulled the floor panels, and made a frame out of 4x4s that sat on the floor in the cab then I used a chain hoist to pull it up from below, I took some longer bolts and put them in two of the side mounting holes to help it stay straight then with some use of my knees, and some swearing I got it to pop in.
Though that being said for such a big transmission it went in easier than the NV5400 in my jeep wrangler.
