- 3,923
- 76
- 48
- Comfort, Texas
Where do you get the stainless steel shafts?
I do believe you and Gerhard. No need for a vent there. If you look at the fording kit it would pressurize the bellhousing that inturn will presureize the transmission and the air will escape out where it can. Most probely the rubber boot.gerhard brings up a good point, the input shaft of the trans has no seal so even if the trans vent is plugged, it will still vent out the front. i wonder if it would carry any oil with it. the trans oil level is way below the shaft, but at speed lots of oil flying around. i don't see how the trans could build enough pressure to get out past the spring/ball vent on top.
tom
Hi TIM, been awhile; always a pleasure to help; have a great one!!charles is one super great guy and really knows his stuff.. he has helped me out many times working on m37.. a very big help
We custom machine the ones we install.Where do you get the stainless steel shafts?
tom[/QUOT
There is no ball in the vent assy. Only a small spring pushing slightly upward on the external cap. It is open all the time unless foreign matter has it clogged.
99% of the vents we see that are stuck; there is nothing at all wrong with the vent itself, but rather rust and or debris has gotten in preventing to cap from popping back. Replacing is fine, but most times a thorough cleaning will accomplish the same thing and saves the cost of replacement.the vents are called Poppet valves. you check them once a while. To check them, push down on them and they should spring back, if not replace them. they are no good.
There is a rubber disk the spring pushes on to seal out water.gerhard brings up a good point, the input shaft of the trans has no seal so even if the trans vent is plugged, it will still vent out the front. i wonder if it would carry any oil with it. the trans oil level is way below the shaft, but at speed lots of oil flying around. i don't see how the trans could build enough pressure to get out past the spring/ball vent on top.
tom[/QUOT
Correct one way valve not open all the time.There is a rubber disk the spring pushes on to seal out water.
I do believe it would be a mod. that you put in the valve when you install the fording kit. If you don't go swimming then you don't need the valve.
I respectfully disagree. The vent is needed, why? First, the shift lever boot if in good shape is sealed up pretty good, certainly beyond the point of a decent pressure relief point. That's good as you don't need oil fumes inside the cab with you. The top cover gasket used on the 3053 trans has a shield that extends back from the front interior edge of the case. This deflects direct oil splash away from the vent port on the top cover allowing free air escape while helping keep oil vapor escape to a minimum.I do believe you and Gerhard. No need for a vent there. If you look at the fording kit it would pressurize the bellhousing that inturn will presureize the transmission and the air will escape out where it can. Most probely the rubber boot.
The transfer case now that needs a vent.
