transmission removal
exoilfld
alto, tx
When I remove the 400 trans; the tech manual picture shows a splined shaft out the rear. My question is; will what the splined shaft fits into in the transfer case remain in position so the trans can fit back into it easily or will it drop or change position?
exoilfld
alto, tx
There seems to be 2 sets of bolts. 4 on one side and 6 on the other. Does the trans mount come off with the trans? The manual does not seem to be very clear.
NDT
5,954
Camp Wood/LC, TX
Either. The trans/transfer assy will be on the ground, if you are rebuilding the trans, the rebuilder will appreciate if you have the adapter off already.
exoilfld
alto, tx
I guess I am confused. I thought I could separate the trans from the transfer case leaving the transfer case supported but still in the truck. Is this not right?
