- 102
- 5
- 18
- Culpeper, Va.
Guys, I went through about 25 pages here and can't find my answer. Simply, what is the best (or close to it) drop-in syncro transmission swap for the M37 driveline?
Thank you.
Thank you.
Steel Soldiers now has an offical calendar available, read more about it at: Steel Soldiers 2021 calendar
Only the 3rd and 4th gears were synchronized in a stock M37.I remember my M37 as having a synchronized gearbox. They were supposed to from 1951 onward.
What is the parts availability and reliability like for those transmissions?If you can locate a Canadian m37 transmission, they are synchronized in 2-3-4. They also use a larger clutch disc, and are based off the T98.
