- 270
- 103
- 43
- Mico, Texas
Do you meant the trans will not go into 3 or 4? Or do you mean you can't get the lever into "H", which isn't the transmission.For some reason my M1038 will not go into high gear. Wanted to get the advice of professinals before I tow it to a shop. Any help would be appreciated.
That sounds more like a transfer case issue not a transmission issue .It's a three speed transmission. Won't work in High, only in High lock, Low and Low lock.
Good call....I thought so too, but don't know enough about it to make the call myself.That sounds more like a transfer case issue not a transmission issue .
Does not move in High at all in any gear....but runs perfectly in everything else....Does the vehicle move in high? If not then a half shaft CV joint could have blown.
Happens more than you think and it's not entirely noticable besides no vehicle movement in high.
Put it in H. Hold your left foot on the brakes. Give it throttle. Ease of the brake, but not all the way. If it moves, the issue is likely a halfshaft.Do you meant the trans will not go into 3 or 4? Or do you mean you can't get the lever into "H", which isn't the transmission.
Yep blown CV joint in a half shaftDoes not move in High at all in any gear....but runs perfectly in everything else....
Right on the money.....put it in high and drive while holding down the brake and as I let off the brake it moved a couple feet....Okay........where in the heck do I get another halfshaft....?Put it in H. Hold your left foot on the brakes. Give it throttle. Ease of the brake, but not all the way. If it moves, the issue is likely a halfshaft.
Or put in H and put trans in gear. No brakes. Have someone move around and find the noise of something spinning that is broken...
eBay, (forgive me for actually spelling it correctly) just remember 12k shafts don't work in older humvees.Right on the money.....put it in high and drive while holding down the brake and as I let off the brake it moved a couple feet....Okay........where in the heck do I get another halfshaft....?
Your humvee has 3 different length halfshafts. You need to find out which one is bad. you could have someone get under it (out of the path of the tires and look for something spinning, such as the "axle" or brake rotor....with no brakes applied while in H and D.Right on the money.....put it in high and drive while holding down the brake and as I let off the brake it moved a couple feet....Okay........where in the heck do I get another halfshaft....?
