Trasporting a m35a2
SPC_romaine
Greenville SC
what do you need to move a m35a2, because it waighs about 14,000 lbs so that puts it around 7 tons I had a trailer that can hold it, and im getting a new one here soon but what kind of pick up would pull that much waight.
I know that sounds like a dumn question. but i need to know thanks guys
tie6044
42
Blaine, MN
I've pulled MANY with my 3/4 ton Duramax and my 34' 21,000lb gooseneck trailer. As long as all the brakes are up to date you should be fine.
midcounty
26
Preston, MD
If you look at the weights of some modern fifth wheel campers, I would think you wouldn't be far off. A good deisel p/u with a fifth wheel or gooseneck trailer should do the job. The most important part will be that you have good brakes all around on truck and trailer.
