Birdman
- 0
- 0
- Nelson, BC, Ca
Yeah, you're right, if you maintain consistent ride height where the angles are correct it should be ok. The vibration will only occur in bump positions. The extra lift increases the joint angles so having it right is more important.
I just got an email from TMR. Their heim balls are 52100 high carbon bearing steel. You know what water does to ball and roller bearings.
Where I am high carbon steel will rust even in unheated buildings.
You should get those rubber boots.
