Trouble separating steering arm from wheel knuckle
Micmada
211
Florida
So, for the life of me, this steering arm which is attached by 4 bolts on top of the knuckle on the picture will not pop out. Wondering if I forgot something. I tried a sissor jack between it and the hub to separate it, and also heated around it with a map torch. It is not budging.
Thanks,
Regards
Micmada
211
Florida
I had to whale the hell out of mine to get it to free the cone washers . Once they are free it’s off easily .
Finally got it off after some energetic hammering. When I got it out, one of the conical washer was still seized up in there. Thanks all. Definitely am thinking of getting a air hammer
BEASTMASTER
142
Burgaw, N.C.
ya, i was gonna say i don't see any hammer marks. never mind the rubber mallet ,get a good 3 pounder and HIT the d--- thing it's not made out of glass !!!!
CMPPhil
376
Temple, NH
Hi
I've found that soaking them with acetone and ATF, over night once the nuts are off, and then as suggested vibrating them with air chisel. I dial the air pressure way down so as to deform the cones.
Cheers Phil
Micmada
211
Florida
I appreciate you all replies. So, I am inspecting now the hub. Once apart, is it normal for the inner roller bearing to have a travel play in the space between the copper seal and the hub bearing raceway?
