Jetnoise400
- 0
- 16
- Sparks, NV
Hi All,
I recently had to pull my oil pan and reseal it due to a badly applied treatment of vintage silicone and a subsequent leak...
So I had to disconnect the trans cooler lines from the trans to get the torque converter cover off, to get the oil pan off, etc...
Everything went back together ok, but now I've noticed a slight drip from the lower trans cooler line at the transmission fitting. It's behaving as if it's loose. I put a wrench to it, and it's tight, so I don't think it's that. I didn't use any teflon on the threads because it's a compression fitting. Did I do something wrong?
The only other thing I thought of (this morning on the way to work) is that when I got the oil pan back in place and reconnected the trans cooler lines, they were pressed up against the back of the oil pan pretty hard. So much so that after I tried (and failed) to loosen things up and make some room I wound up putting a bit of fuel line between the lines and the pan to keep them from rubbing. Plus the clamp that attaches to the torque converter cover was difficult to put back on and might be putting a bit of a side pull on those lines.
Any and all suggestions greatly appreciated! Sorry for being so wordy
