dmetalmiki
- 2,033
- 113
- London England
So we are invited to a emergeancy services meeting sunday. We turn out at 8-30 and start out to the event..my fire truck slows..stops..WTH?...crank//go 20 yards..crank again..another 20 yards.(18 meters!)..the m715 behind in convoy tows me all the way back (backwards) to the workshop hardstanding. So, check the fuel supply..ok. Check in tank pump..AH! not running..so wiggle the plug..and pump starts running. Truck starts..then goes another 20.34 yards and stops again! WTH?,,tow it back yet again. Slack off the fuel pipe out of the tank..."big squirt"..go to the filter under the engine..Nothing! ...change the filter..ok..Nothing at the two filters on the engine!.. crack the pipe TO the fuel pump..= Squirt..WTH?..nothing out of the filters..AH! ok..so 150 psi into the disconnected feul pump "in" line..(with line to filters disconnected)..and Clumps of..c...p! fly out. ..hmm..ok..clean out all filters and install new..re-check..and fuel flows again. Who would think that that inlet to the fuel pump ( or INSIDE ONE WAY VALVE ) was clogged? this could be a MAJOR problem for drivers out on the road. Who would check this? so, pump line "in" blown out..(with pump out line disconnected) and all lines re-connected..truck starts up on first push of the go button. So..IF your deuce (or 5ton) stops and filters ok..CHECK the one way valve into the fuel pump inlet.
