Trying NOT to slay the Draggin'
20,738
Thanks! May have to start carrying some of that. I managed to have success using the cringe worthy method of holding the lines w/ vice grips while turning the nuts.
Few hundred miles later and all is working good in that department! Now the current issue is w/ my T-case. It's throwing a lot of oil so I know a least one seal is bad but it's also popping out of low range. Wondering if that could be and adjustment since the lever sits right on the floor when in low and maybe that's not engaging it far enough? Or is it something internal?
"Sent w/o me knowing"
Might very well be that the TC lever needs adjustment (like you mentioned). Remove the floor board and see if it works a little better? If so, a little adjustment will improve it - before you ruin it - by running it partially engaged.
LowTech
162
Arizona
That's a good idea! Now that we're at our destination and I have the trailer unhooked I can try such a thing. As far as running it in that condition, one it started to happen I quit using low range until I could figure out what was happening. This latest trip has been almost entirely pavement, so high range only.
Time to check into how it's adjusted.
Does any one else have their T-case lever hit the edge of the passenger seat when it's in high range?
LowTech
162
Arizona
I don't think mine get that high.
Noted, thanks.
I haven't yet tried maneuvering around w/ the tunnel off as I didn't have a spare left after the trip and wasn't going to take it anywhere, even a short distance, until I knew I could get it back if another tire went out. Once I got a new tube and mounted a tire for the spare I had to leave state for work. So . . . a couple months from now I'll be back digging into the linkage, possible adjustments, and see what's really the issue.
Sent without me knowing
