Trying to find a rear popeller shaft part number 14067762
funderca35
Gaston, South Carolina
Hey all,
Working on an M1009.
Hoping someone can steer me in the right dirction. Im trying to find part number 14067762 the rear propeller shaft. I can find the front shaft all day but no where have I been able to locate the rear. It dropped on me while driving on Monday I know why truely my own stupidity..... late summer I used it to remove some small-ish stumps and got sand in the u jonts and could never get it out which made them noisy and just not in good shape. the shaft broke at the front u joint and of course broke the u joint. trying to find whole assembly.... anyone have any ideas on where to look.. Ive looked at all the regular supply houses and from reading other threads have determined that I caqn use one off a regular K5 but cant find one of those either.. Help, please!!!! thanks
chad
Ken_86gt
Williamsburg VA
Wow, I have never heard of a k5 with a propeller on it- how does it do in the water? Can you post some pictures? Also you should never use a propeller shaft to remove stumps.
Now if you need a new drive shaft repaired you need to find a drive line specialist in your area and have it repaired, it will probably cost less than a new one. If you can't find one try a off road shop for their recommendation of a local shop.
porkysplace
1,496
mid- michigan
try any of these Dana/spicer dealers
FLEETPRIDE INC 316-GNV1137 White Horse RdGreenvilleSC29605(864)277-8362(864)299-1831-View
FLEETPRIDE INC 310-COL1631 Shop RoadColumbiaSC29201(803)799-4812(803)799-2833-View
TRUCKPRO GREENVILLE1144 White Horse RoadGreenvilleSC29605(864)422-1800(864)422-1001-View
FLEETPRIDE INC 328-NCH5130 Rivers AveN CharlestonSC29406(843)747-1547(843)744-5342-
funderca35
why does the tm call it a propeller shaft same ?
1 PAOOO 11862 14067762 PROPELLER SHAFT WITH 208 TRANSFER 1​
CASE
but thanks your comments are duely noted and have been a a great help!
K9Vic
Fort Worth, TX
Did you try the local junk yards or Craigslist searching K5 or Blazer? I will often frequent CL for used drive shafts for these as you never know when you will get a M1009 with a bent one. This is because it is cheaper over getting it rebuilt at a drive shaft shop, but that is the place to got get them fixed.
K9Vic
Fort Worth, TX
Thanks porkyplace.... I'll start making some calls. I was able to get a quote from WB parts $803 that sounds so high.. would like to see if I can fix this one..
Call them back and tell them to go pound sand, that is freaking ridiculously over priced and have never seen such BS for a drive shaft. I had mine rebuild with two new u-joints for just under $200, but I do not recall the exact cost. As long as you have the front and rear sections and they are complete, the drive shaft can be re-tubed. This is how they extend them for lift kits. I have a spare one that was used on a 4" lift if I ever wanted to do that to my M1009.
funderca35
I pulled about 30 stumps with a thick chain and a stump grubber. small 4" to 6" cherry stumps did a real good job to be honest but stupid. The tractor was broke down 53 ford 9n so i really wanted them out of my hay field so i got stupid and used my beloved M1009... Yeah, i'm really pissed with myself! choke cherry trees are poisonous to goats and the stumps dont die just start regrowing...... darn things gave me the worst time with my goats last year so went on a crazed removal campaign... lost that battle but im still fighting the cherry tree war! OK i know it all sounds stupid but i lost most my kids last year to the yellowing leaves...
funderca35
I have all the peices but the shaft itself where it holds the front u joint is broke completely on both sides or both rings that would hold the u joint.. but I have all the parts that are left :) had to take a drive back down the road to find the slip on yoke assembly.....
Warthog
244
OKC, OK
WB Parts supplies goods to the gooberment. I can beleive a new driveshaft would cost $800.
funderca35
Wow.. i just bought a 96 grand caravan for 700, lol..... use it to drive the kids to school and work and all.. but i think i might be on to something porkysplace gave me i got a quote on a used one for around 150 here in SC and I'm gonna call the gentlemen he returns from lunch.... got my fingures crossed!
