nyoffroad
- 743
- 93
- Rochester NY
This may be a long shot but it's also worth checking, these trucks are old and so are the wires and connectors. I chased down a intermittent starter problem and it turned out to be the small purple (IIRC) wire that goes down to the starter solenoid, the wire itself was fine, it was loose in the crimped on ring terminal the nut holding the terminal on was tight. I also had an aftermarket hi torque starter that melted the silver soldered connection on the copper braided wire that goes from the solenoid to the motor itself. hope this helps.
