Just imagine trying to line up both brackets to the frame that have 4 bolts each to go in. With the straps tight it's extremely difficult to do that. So I leave them loose and move them around until all 8 bolts are in the tighten everything down. Makes it a 5 minute deal. I don't bother with a jack either. Prop it up with the knee and go at it. Dang jack just scratches the heck out of it and gets in the way. I get enough new line to hook up when the tank is on the ground then it coils back up when the tank goes back in. Gotta pop the ground wire through the frame hole too. You may need some roofing paper or some tire inner tube for the strap mounts.OK I think I know were your saying. I am a visual learner only lol. When I get into it if I have any issues I will tag you in the post if that's ok? It does seem really straight forward though when looking at it.
Sent from my SM-S906U using Tapatalk
