Tubes and flaps for 1100r16 Michelin tires
808Morgan
20
Greenbrae, CA
I see some people on here have some 1100r16 tires, I recently bought some XZL and I don't really see any tubes other than tractor tubes with a short nubby valve stem. All I can think to do is use valve stem extensions? Curious what you use, people have told me to use 900r16 tubes but another shop said it would be dangerous. I'm restoring a decent set of combat wheels to put them on but we need to figure this out.
Any help would be appreciated. Thanks!
808Morgan
20
Greenbrae, CA
I would ask militarytires.ca as they sell the tires and might be able to point you in the right direction as some Canadian tactical vehicles use them or used them recently.
Ok thanks, I have had some people tell me the 900r16 tubes are just fine to use but I wanted a professional to tell me before I try it!
royalflush55
520
Reydon, OK
You might look into a tractor tube with a TR218A (air, liquid valve). It has the removable valve core housing that might be a little longer than a regular TR15 rubber stem. It will also be more sturdy if you have to add an extension.
juanprado
2,737
Metairie/La (N'awlins)
My opinion is stretching the tube is ify and in the day when I ran Western auto stores, I would not install bias tubes in place of radial (other was ok) or install the wrong size tube.
A farm radial tube might be ok but not sure what speed rating it is but the m37 is not an indy roadster either.
808Morgan
20
Greenbrae, CA
I talked to a shop guy at Vintage Power Wagons, he says they have been putting the 900r16 tubes they carry for the Super Lugs etc.. in the 1100s and they seem to be fine. I have some tubes from my old Super Lug tires that we can try as an experiment, it may not be a problem after all, I trust the VPW people.
