Turbo ID help
searls84
Las Cruces, NM
I need some help ID'ing a brand new turbo I have and the motor(s) it would have been found on. I have found that it was used on a Mack but no model number of motor. Thinking it might be for the M39 series with the Mack ENDT-673? I want to sell it but need to figure out exactly what it is and is for first.
It shows on the data tag:
Schwitzer
S/N 4LE-504.J1480/317
P/N 631GC559A
simp5782
Feo, Fuerte y Formal
9,268
Mason, TN
It is off a MACK. Will fit a 673, 675, 676,711 It really doesn't matter what you want to put it on.
AMGeneral
112
Connelly Springs, NC
Correct turbo for an early ENDT 673 Mack for the M39 series truck,updated version(different bearings),hence the A designation after the Mack part # 631GC559
It may also fit an early LDS 427 multifuel,I cannot remember if they run a wastegate or not.
wcuhillbilly
Devils Tower, WY
call Blaylock Turbo Ph: 620-856-5227 in KS, give them the numbers in the tag, and they can tell you what "base" you have, that will determine how many differant engines that turbo can be used on. most of the big trucks used only a couple differant base sizes,,,, thus the same turbo can fit multiple cat cummins, mack configs.
