Turbo question
tguinn
114
33
savannah,MO
I have a D turbo in my Deuce currently, i feel like it has too much play in the shaft, (feels like 1/16"), will a C turbo work till I rebuild the D turbo?
Elijah95
Certified Rookie
1,239
1,183
Georgia
Side to side or in-out play?
And yes a C will directly drop in no mods required as far as I’m aware
Elijah95
Certified Rookie
1,239
1,183
Georgia
Is that a dry or wet test? Meaning, have you ran the engine prior to checking play?
I ask because It is normal on most all turbos to have a little extra play after oil has drained away
Elijah95
Certified Rookie
1,239
1,183
Georgia
I’d recommend running it, and re checking after shutoff. See how much of a difference it makes and let us know
Crf450x
347
Fall Branch, TN
Side to side play is normal. As long as it's not rubbing the housing you're fine. They use journal bearings so that gap is filled with pressurized oil, similar to rod/main bearings.
tguinn
114
33
savannah,MO
I plan on starting up the truck when i get a little farther along , but before i put any sheet metal, ( hood, fenders, etc), to check for leaks and address anything that pops up. I will check the play after i run it and then see how much play there is. I misread the turbo code on the one I was looking at, it is a D turbo, went ahead and bought it, is a NOS one, and got a good deal, so either way I will have a spare.
tguinn
114
33
savannah,MO
Follow up; After bringing truck up to temp., let the turbo cool off enough to remove the exhaust elbow. Like was mentioned, the play is
almost nonexistent. I appreciate everyone's input.
frank8003
4,976
Ft. Lauderdale, Florida
Do you have the anti drainback oil filters on your truck. If not then sometimes in the first 90 seconds of engine run you will hear the turbo stop screaming when it finally gets lube oil. All lube oil drains to pan on shutdown as per design.
tguinn
114
33
savannah,MO
Yes, made that switch over the winter, along with several other changes. Tim
