turbo rebuild time.....
Crackerjax
Fuquay, North Carolina
well it seems I have a turbo to rebuild I wish I could find someone local here in raleigh but no luck ...
the center section of this turbo is ok spins freely with no turbines on it .. the exhaust turbine is rusty along with the inside of the exhaust housing causing drag because of rust buildup I beleave this was caused by the truck not running for a number of years and water filling up the pipe......
the intake.... the leading edges of the turbine are a little boogered up...seems the might of had an airfilter or lack there of problem.... the housing is great and there is some oily buildup on the inside.. this may be caused to bearing seal failure?
so I need the snail cleaned up inside and out and both turbines redone and new seals and might as well put a new bearing in the center section.....
whats a reasonable price for this service and a good shop I can send it to....?
thanks
Crackerjax
how much do they run new? I called around and they want $600+ for a used c turbo. I have a good d that came with the truck... I just figured I would have an extra turbo and a c one at that..... I wonder if I can mix ans match a d with a c to make a louder turbo with a better sheilding and bearing.
Crackerjax
well I got a price the lowest so far is $400 for a rebuild... I can get a used c turbo for $600 with unknown condition.. I have a working D turbo I would just like to use the C and then have the D as a spare... any other options??
thanks
ken
24
Houston Texas
If your intrested send me a PM. If your rotor is ok i can do it for much less. If not the parts would cost much more than it's worth. If your compressor wheel or turbine edges are worn/dammaged. I'd sudjest getting a replacement. Even though it might be possable to rebalence the rotor it will be less efficent. If your D is in good shape i'd sudjest using it. It's a much better turbo.
