Turbocharger break down
twisted60
241
Jupiter, Florida
I have an 1152 6.5TD, looking for parts break down of turbocharger, pictures of disassembled unit, troubleshooting info etc.
I don’t think mine is working, I test drove it with doghouse and heat shield removed, before test drive I confirmed the waste gate moved freely. Waste gate never moved during test drive, rpm from idle to 2500 and no movement. Didn’t see any turbocharger troubleshooting info in ’s and only part was entire unit.
Sent from my iPad using Tapatalk
Mogman
8,297
Papalote, TX
It is a standard GM turbo more or less (GM-7) not much to it actually.
It uses a spring loaded waste gate, simple as can be.
You can look up info on Gm,6,7,8 ect, all about the same construction.
I agree you should put a gauge on it first.
diesel_dave
285
Utah
Does it make any turbo whistle? I was also afraid mine wasn't working when I first got the truck because I never saw the waste gate moving but it definitely has some turbo whistle if you floor it.
Mogman
8,297
Papalote, TX
I can only hear mine when it is cold and idling, of course I am old and deaf. :(
Mogman
8,297
Papalote, TX
Unlike my DuraVee which sounds like an M35 on steroids, I get comments all the time from folks that tell me " I heard you in town today"!!
TOBASH
3,010
Brooklyn, NY
Guys. Turbos whine before they whistle.
The whine is the cartridge spooling up. You shouldn’t hear whine at idle.
The whistle requires higher RPM and represents the wastegate blowing off excess pressure. You shouldn’t hear whistle at idle.
Excess pressure is defined as the pressure setting on the wastegate. HMMWV units are set to 4 or 5 PSI IIRC. Mogman posted on how to defeat the military retune and reset. Optimizer should safely accept 9 psi, but remember to increase IP output so as not to lose out on max power (Mogman correctly pointed out that running lean is safe in Diesel engines and I corrected). Don’t modify without a manifold pressure sensor to prevent too much pressure blowing your 21-1 compression pistons and heads.
Besides proper IP output, water injection is also a great way to increase HP while decreasing EGT’s. Also consider getting an EGT sensor.
Sorry to go a bit off point about EGTs and IP and compression ratios and such.
