turn signal accuation whats wrong
Jones
Sacramento, California
I'm not sure but I think the wiper and turn signals are on the same lever. This should be close enough to a civvy truck to be able to compare the two.
Wiper controls should be a small bundle of wires going down the column. The tan plate is the contact and cancelling piece for the turn signals and it should have a corresponding contact plate under it with it's own wire bundle.
Look in a parts breakdown to be sure I'm not leading you astray.
69dieselfreak
rimrock az
exactly rite but how does the wiper switch accuate the turn signal switch thanks for the help where would i find a good parts break down thanks for the help again
Jones
If I understand the question; your wipers active the turn signals?
If so I'd look for frayed wires touching each other due to them winding up and unwinding as the steering wheel shaft is turned; or maybe something shorting across the multi-pin connectors.
Not much room inside the top of the steering column and plenty of places where wires can get pinched.
69dieselfreak
rimrock az
no i just replaced a broken wiper switch and missing lever on the on the our side of the steering colum what im lookin for there must be a lever or something going from the wiper switch to the turn signal switch and what im wondering maybe where could u get one of those with out buy a complete steering colum from like a junk yard
thank for the help
