OK for some history, I recently aquired my first duece and I am trying to get the turn signals and brake lights working.
My headlights and running lights work fine. If I turn on the turn signal lever , nothing. I can take the connector off the flasher and jump the conenctors and I can get the turn signal lamps to work along with the interior turn signal indicator. I can also very the grgound on the flasher has good ground vi aOHm meter. I assume I need a new flasher yet I have found a mystery wire.
This wire runs from the engine compartment , under the truck and is cut off inside the frame rails just past the air tanks.
I have included pictures along with some pictures of what i belive in the new brake light connector switch.
Oh and I hav eno brake lights what so ever. Everything else works including all blackout and interior dask lights.
Can you confirm that my flasher is bad and 1. help me diagnose my brake lights, and 2 what is the mystery wire.
Thanks
Thanks
