Turn signal comes on, does not blink.
jgreen52888
Millington
Hello,
The truck is a M1120A4 LHS. The turn signal/hazards light have and come on, they do not blink. I have replaced the turn signal switch, the hazard light switch, the ground wire, and the high beam switch. There no other fuses tripped that I can tell and there is correct voltage going through the harness. What would keep it from blinking?
20,760
Hello,
There should be a flasher - just like a normal truck.
TM 9-2320-279-24P
Page 88-1
PDF Page 282 and 283
GROUP 0608 MISCELLANEOUS ITEMS
Hopefully?
FIG.88 TURN SIGNAL SWITCH AND
FLASHER
MarkM
1,149
2,098
WOBURN. MA.
On my M998 when I replaced my directional bulbs with Leds my blinkers no longer worked. The flasher needs more resistance than the Leds were giving. I put the incandescent bulbs in just the front and the blinkers worked fine. This may be your issue if you replaced the bulbs and then had a problem.
Mark
