- 1,750
- 2,396
- 113
- Rosamond, CA
Good chance the turn signal switch is wack.
Back blinky circuit busted, CAMO
Adding little tid bits..... Spins a new web.........BOO
What do you mean both low and hi at same time. In the lamp bucket you have the larger stop/turn single contact bulb and the single contact smaller tail bulb.
Then the BO lamps or LED set. OR are these all LED.
Need to figure out when and what's going on... Markers on / off, left - right turn - stop, check brake switch ? and make a logical deduction to what is affecting what and when.
Got a picture of the wiring in the back junction boxes. If all mudded up, rusted or have you replaced buckets . Did they ever work? Come clean with the info.
So what lamps and when are they working? This is turned into a HumV of horrors... LOL
Halloween gremlins are taking over here, CAMO
