turn signal issues
SgtMajHarper
624
Falcon, CO
I have the newer style solid state flasher conversion on my truck. This has been an on again / off again issue for a couple years that started as a one off then started happening more and more overt a couple of years to where now its almost just not working at all. You start out and it works fine (maybe), sometime later you turn it on and it may / may not work or decides to come on if you leave the lever activated, then goes off. Lately when I first flip the lever I get a quickie flash on the indicator light looking like it's trying to work then nothing.
I unplugged the connectors to make sure no gunk, etc.,. everything nice n clean, all wires are nice n tight, nothing there. I used a test light in a couple locations and have steady power going to the flasher and the switch lever; but when the flasher is unplugged, the front turn signal light bulbs and rears come on steady (odd). Also get a steady on with the indicator light on the turn signal lever.
Without anything else to go on I'm going to install a new flasher box and see if that is the fix.
dmetalmiki
2,036
London England
Check all the grounding (Earth) wiring. That sound typical of an earthing issue.
If you put a hot (Live) wire to the connector at the switch, first to the right and then left it should light the left rear and front, or right rear and front, Nothing else.
SgtMajHarper
624
Falcon, CO
10-4.......I'll check for grounds.......thanks much.
SgtMajHarper
624
Falcon, CO
Yes get it out of the way early or curse in a language it doesn't understand. No guaranties but it's worth a try. :unsure:
Ok, advice is advice......I'll try it because what I have been doing so far doesn't work a lick. (I'm blaming it on 2020)
20,760
Yeah! Your truck has the Chinese Virus... That's it! :cool:
I hate it for you. My S&S M1088 is supposed to have self cancelling turn signals. The "self cancel" part seems to work properly about half the time. Similar but different. Frustrating all the same.
GOOD LUCK on your repair!
SgtMajHarper
624
Falcon, CO
Checked the grounds and to be double sure cleaned them up and retightened, nadda. Weird.......gremlins.
SgtMajHarper
624
Falcon, CO
So I tried the easy way out, looked in the easy to reach places like under the hood, inside the turn signal switch itself with no joy...installed a NIB solid state turn signal unit. Now I get a left turn blink just like you want, then flip to the right and I get 4 ways flashing. I'm kinda thinking I have a wire shorted out somewhere making my issues. I've decided I'm going to start under the dash and start separating wires from each other working my way to the tail lights and see what I find.....when I have a little more time and it's warmer outside.
glenn715
fortuna CA
Check your bulbs first. I've seen where a dual filament bulb has one filament burn out onto the other filament and do some weird stuff. Also try isolating different parts of the circuit to try to pinpoint the problem to one specific area. Example unplug rear tail light harness and see if problem is still there, if it goes away then problem is in rear section.
SgtMajHarper
624
Falcon, CO
Thanks much Glean....good advice and kinda where I was thinking of trying next wiring wise.....hadn't thought about the bulbs being the culprit.....all I need now is some warmer weather and less wind. I've been busy tinkering on the Goat lately and been distracted off of the M715.
