HellonwheelsV-100
- 1
- 8
- Scappoose, OR
I searched the other threads and didn't see this issue anywhere (hopefully I wasn't just blind)
Anyway-
Here's the symptom-
When I put the turn signal in the left position, both front and rear left signals work correctly.
When I put it in the right position, the front right signal works correctly but BOTH the left and the right rear signals flash.
I checked the ground on the signal, and the flasher unit, and the light housings.
I replaced the turn signal with a NOS one, but still have the exact same issue.
All of the positions on the light switch work correctly both front and rear.
When I apply the brakes, both rear turn signals go steady on if in R turn position. In left, they work fine.
Any ideas?
Anyway-
Here's the symptom-
Any ideas?
