Westo
- 42
- 18
- Seattle, WA
My truck came with no front composite lights and a flasher unit removed with the cable cut before the connector. I just got finished putting on all the parts and wiring everything back together but the turn signals are not working. The first time I turned the right signal on it worked front and rear, but turning it to the left did not. Nothing happened when I turned on the hazards, and now even the right doesn't work. The indicator light on the turn signal stalk turns on when the signals are engaged, and I've checked all the bulbs around the truck and they look to be intact.
After these first problems, I noticed the front composite lights didn't have the ground loop installed. I attached that on both sides but I still have the same issue.
Any ideas as to what the problem could be or troubleshooting steps are appreciated.
