Turn signal problems
AlexFolino
Pittsburgh Pennsylvania
I have a 1986 m1008 CUCV. Truck has turn signals on the driver side front to back however on the RIGHT side i have no marker or front turn signal light, i do have the rear reverse and brake light but no turn signal. Basically turn signals are inop on the passenger side. I changed all the bulbs originally with no luck. When i turn the switch to the right it does not click but when you turn left it does. Before i pull the wires out could it be a flasher? I did clean all the grounds that i found on this truck but no luck so far..
taildragger03
Reno, NV.
Try another flasher. Check the grounds again. Also, check the sockets themselves. I found a crack in one of the contacts within one of the bulb sockets. Caused all kinds of issues. Replaced and no more problems. Photo below explains.
davidkroberts
23
west tennessee
i had one that did that, its your turn signal lever on the steering wheel. If i read your post correctly it clicks into place on a left turn but doesnt click into place on a right turn. The reason you arent getting the clicking on a right turn is the signal isnt traveling from the signal lever in the first place. its stopping at the steering column. If you are concerned about the grounds get your test light and start checking circuits for a break in the circuit.
