4bogginchevys
- 1
- 0
- rathdrum idaho
is the baseball diamond thing the cover plate below where it says stanadyne in jags post...(2 bolts hold it on)? How do you know if someone else has turned it up, is there some noticable quality of the engine that is bad, without knowing EGT's.... and should I aquire a gasket for this for re-installation of that cover? Thanks
btw, If the throttle is mashed than a LITTLE black smoke is all that shows up, dissappears about 2' out of the pipe. Does that resemble a turned up pump or stock?
