Turnsignals on M211?
badgeboy16
Greene, NY
Yes, I'll admit I'm new to this, but am I missing the obvious, or does this truck not have turnsignals? I got a copy of TM9-8024 yesterday and can't find any reference to turnsignals. I am trying to read the manual and familiarize myself as much as I can before its first voyage on the pavement.
Has anyone put turnsignals on a M211 possibly using M35 parts? (I have to register this truck commercial, so it will have to pass inspection.)
This is probably a stupid question, but does anyone have any thoughts on this?
badgeboy16
Greene, NY
Maccus or any others who have done this,
Could you please tell me which parts I need?
Turn lever, Flasher, turn signal harness........is this it?
M215
Spotsylvania, Virginia
M211 turn signals
When restoring our M215, I wanted to add turn signals for added safety. I adapted the existing black-out lights / wiring for the turn signals. Added a signal switch to the column, flasher unit and flasher harness from a M35. Used full red lens tail lights (Gama Goat?) and changed the front light covers to custom made full amber lens. Get the manual that has the wiring code numbers to figure out what wires to adapt.
badgeboy16
Greene, NY
RE: M211 turn signals
Thanks guys! I will be gathering the required parts ASAP.
M215, What manual do I need that will tell me the wiring code numbers? Just the TM?
CGarbee
552
Raleigh, NC
You can find a list of the M series wiring circuit numbers, along with the three lever light switch and turn signal switch pinouts, on the olive-drab website's tehcnical data page located at:
http://www.olive-drab.com/od_mvg_technical_reference.php3
Specifically, the wiring numbers are found at:
http://www.olive-drab.com/od_mseries_circuits.php3
I also have a page on my website that discusses how I added turn signals to my M37's and M38's... That page is located at:
http://www.garbee.net/~cabell/turnsignals.htm
Good luck.
badgeboy16
Greene, NY
Thanks everyone! I think I have the info needed, ...now assembling the parts. I hope I'm not getting in over my head with this project!
