Turret Leak Fix Materials
GMVguy
23
Utah
Gentlemen,
To prepare for the eminent leaks this winter, I am attempting the instructions in the attached newsletter. It calls for a specific inner tube, which I am unable to find. Has anyone attempted this, or have the inner tube they can mail me? It's NSN 2610-00-051-9602
GMVguy
23
Utah
I assume this is the biggest problem... water leaking around the bolt holes. Couldn't I use the rubber from a large-enough inner tube to cover this "channel"? Maybe cur it to fit around the ring and then seal it under the little stock seal, over the bolt channel and then seal it to the roof using silicone, etc? Anyone have a better idea? Appreciate the help.
Retiredwarhorses
4,072
Brentwood, Calif
Those half moon retainer plates plates should have sealant applied to them and anywhere in between them, also your would seal around the bolts. That stripping you added might be a problem, the turret tray sits only maybe a 1/4 in of the top of the roof when it bolted onto the turret bearing. If you already haven't test fit it...I would now and make sure it does not interfere. And let me add....slantbacks leak! Period...and it your case, you have a GMV, so if it's raining your going to get plenty of water in the cab when you stop the truck....
GMVguy
23
Utah
Thanks. Yes, I will be mocking everything up (as per your previous advice) before torquing this thing down. I was hoping the added weatherstripping would work, since it provides some cushioning and possibly a little leak prevention. Once I get the tray on maybe I'll come up with better ideas for keeping the water out of the channel. The one thing I'm not sure of is, can't I just cover up that channel completely? Then I'd only need to worry about water getting in within the turret bearing.
As for the GMV rear curtain area, I am fabricating a rear wall and sealing the bulkhead divider to prevent the stoplight bath. Thanks once again for your help!
readyman
Elk Grove Village, Illinois
When moving it seems there's a vacuum created in the cab that sucks rainwater in no matter what. :)
Puddling water accumulated in the lower ring channel will eventually seep/slosh in(hatch, thru-bolts). One time after a long trip I had 4 inches of water in the forward footwells, I installed boat 'drainplugs' in all the footwells to in help draining them out.
2w091
Kentucky
I tried chalking everything I could think would cause a leak, then weather stripped around the turret and rear hatch. I finally resigned myself that I'm getting wet regardless, especially when I stop or turn.
We use ours in bad weather almost exclusively, I'm not interested in looks, just functionality. I'd say I've reduced leakage about 80%, plus we keep it in a garage when not in use.
SETOYOTA
441
georgia
We use to just put a tarp over it. It actually says this in one of the ps mags or TM supplement.
GMVguy
23
Utah
Well, to make my turret leak a little less, here are my steps in applying the recommended maintenance in the above PS Magazine. I chose to use a 1/8" thick 4'x4' square of heavy duty rubber instead of an innertube. The hatch seals up nice and tight, and no water leaks in, after sealing the hatch hinge as indicated in the last picture. Hope this helps you guys stay dry!
GMVguy
23
Utah
Yep. It stopped 90% of the water from coming in... even in a rainstorm. There are small gaps & creases that allow water in, but would be too much of a hassle to try and seal. This was a successful "axe approach" to weatherproofing!
persianhunter007
US
Good Deal. I am trying to figure out a way to seal up our departments HMMWV's.
If there are people trying to find a source of material to use as a gasket, In Afghanistan we had a similar problem and I had my wife send me a 20ft section of shower liner that they sell at home depot and it worked great. I used it to seal 2 vehicles because the rubber sealing material required longer bolts to use. We didnt have enough rubber and no longer bolts. We also installed a drain line in the track and ran it outside. This I think helped the most. Unlike public perception, Afghanistan gets a good deal of snow, sleet and rain and there are no sand dunes in most of it. It's more like Colorado but the mountains are bigger.
Sent from my SM-N950U using Tapatalk
TOBASH
3,246
Brooklyn, NY
Which exact HomeDespot material did you source?
TIA,
T
