Turret Support Pillar - M1045/6
Gamble
371
Los Angeles, CA
I see no reason why the ring can’t be made from stainless steel or regular steel bar. Sure there will be slow galvanic issues BUT especially stainless will minimize that.
Unless of course you’re worried about weight... LOL.
I think the same thing. But I wonder the expense of the first prototype. Once its confirmed and everything works then it would be easier to run off a batch of them. Everyone with a turret hole in their trucks A2 series and earlier could make use of them. But its eating the cost of the development and ensuring youre precise on specs.
BLK HMMWV
564
Pasadena California
Well I don't think you or anyone can make them for less then the people that already have the tooling.
And we know theirs are to spec.
Sadly your going to also have to make a deal with the original manufacturer of the C pillar as most trucks will also need those.
I'd want a guarantee from them that whomever agrees to their terms becomes the sole distributer of them and none seem to sneek out the back door.
Gamble
371
Los Angeles, CA
The idea here is that the ring WON'T make use of the unobtainum parts. It would use the gov planet parts which are more common. Again, The GovPlanet B Pillar has 2 bolts going through the center of the Pillar. This new ring would make use of that, the existing attachment points on the A Pillar and the GovPlanet C Pillar. It would use Grade 8 bolts and Maybe the C Pillar would need Holes drilled through for an attachment point as it doesnt come with pre-drilled holes like the B Pillar. This should make installation simpler as well.
BLK HMMWV
564
Pasadena California
I guess it would help me visualize more of what your trying to do if I knew what all the Gov. Planet B,C pillars looked like in the first place.
What bearing will it use? What hatch? what weapons tray? what locking system .
Or will all that also have to be made to fit the new stuff?
Gamble
371
Los Angeles, CA
Here is a Turret of the 1151A1. It appears the 1151s dont make use of the turret support. The unfortunate thing is that these roofs are significantly wider than the 1045a2 roofs. Otherwise, these may be the way to move forward without the rare and expensive turret support
86humv
541
Texas
That wide overlay roof comes off, and there is a standard aluminum roof under that,,,,that one in the pic shows an adapter ring for a 1114 / mrap bearing which is easier to find....but I bet that 36 hole ring adapter will be removed.
Gamble
371
Los Angeles, CA
Is the wide overlay roof armored? Will the aluminum roof under it fit the 1045A2? If so, this may be a viable option to eliminate the need for a turret support. Does anyone have dimensions for the under roof?
Action
1,564
East Tennessee
There is a 1/4" thick aluminum roof that will allow regular doors to fit. The overlay is another 1/4" or so. You can still use regular x-doors or soft doors with the overlay on, if you don't mind the hmmwv looking like the Flying Nun.
An m1165 roof will work, too. Just remove the round hole cover.
How many m1151 or m1165 roofs have you seen for sale? Or are you looking to buy an entire truck to take the roof off of it?
