StrykerPez
- 1
- 0
Anybody consider propane injection?
Want smoke????? Want to avoid detonating your engine???? How about you just put a fitting in the pipe just after the turbo and inject a spray of raw diesel , that ought to get you about the same results. Not sure if the EGT would be high enough to cause it to ignite or not, might not be enough oxygen. Lots of smoke, wasted fuel going up the stack as smoke and no worries about turning your multi into a boat anchor.![]()
it's fuel, not a catalyst. a catalyst initiates or accelerates a reaction. propane doesn't make the fuel burn better or faster - it's just more fuel [and more egts]. if you add more fuel, you still need more air to burn it.Its a catalyst .also will drop intake charge temp.
(need the picture of the pink deuce with bling wheels and blazer axles here..)
A 466ci engine running 2,000rpm would equal 932,000 cubic inches per minute. Divide this by 1,728 (12x12x12) would give you a CFM of 539. This would be with no turbo. A turbo would compress the air making you use more air then would have space for it.......thus the compression.Does anyone know the CFMs these engines require?
Any input on this would be appriciated.
wow - so how was your conversation w/ Corky?... couldnt get anything but one is turbo and the other is super charged.....
