- 1,716
- 1,805
- 113
- Nova Laboratories, WA
I have 2 group 31s (950CCA) on the battery tray closest to firewall.
I love my Group 31 Exides from Tractor Supply. $100 each and still going strong. Just started my M1031 after sitting for two months outside in freezing temps, fired right up without hesitation.
Yup. Ratcheting tie down strap to secure them.Cool! No mods to the tray? They just fit?
This probably wouldn't be my preferred method. I have seen batteries come out on the trail even with a factory tie down. An Optima will actually work after you run it over.Yup. Ratcheting tie down strap to secure them.
Is that the dual battery tray that optima makes?Here's my setup using the factory rear battery mount as a base . . .
Battery Type/Model | 6TL | 31M-PC2150 | YellowTop D31A |
Width | 11.875" | 13" | 12.875" |
Length | 10.5" | 6.8" | 6.5" |
Height | 9" | 9.39" | 9.375" |
Weight | 73lbs | 77.8lbs | 61lbs |
20Hr-AmpHr | 120 | 100 | 75 |
CCA | 825 | 1150 | 900 |
Warm CA | 1010 | 1545 | 1125 |
Reserve Minutes | 215 | 205 | 155 |
Retail New (quick web search) | $295 | $350 | $250 |
Here's the correct link: http://www.sears.com/diehard-platinum-automotive-battery-group-size-35-price/p-02851035000PAnyone have any experience with Die Hard Platinum batteries group 35 (http://www.sears.com/diehard-platinum-automotive-battery-group-size-35-price/p-02851035000P)? I have a pair of 31M's that are a little too big to have them both up on the front battery tray, which i need to do to make room for a turbo install.
