Two Questions about Turnsignals and Brake Lights on M812
armytruckdiesel
Where is the brake light switch located on the M812 Bridge Truck? I noticed something on the air line with two wires near the master cylinder.
My turnsignals are not working and I noticed that Saturn Surplus has this for sale under M35 parts.
http://saturnsurplus.com/m35/3706.jpg
Does this turn signal assy. also fit my 5 ton?
Thanks,
Andy
dabtl
Denton, Texas
That is probably the main problem with the turn signals on your truck. That is because the flasher is the main problem with the turn signals on everyone's truck. It will fit, it is delicate.
acetomatoco
9
And it needs a good ground, if it is on the fender, the fender needs a good ground...etc etc...The brake switch on early M35s was a hydraulic unit like a Jeep but they changed it to air operation after failure by leaking emptied some master cylinders... oops no brakes... The air switch looks like a small floating mine...with two wire connectors typically of the Packard type....
CGarbee
579
Raleigh, NC
It's the generic M-series solid state flasher unit. It'll work on the five ton as well as the M35... :)
The brake light switch on the M812 is mounted on the frame rail if my memory serves, and has two wires on it. Sounds like you are looking at the correct part from your description. The one for the M817 (and I think the wreckers) are located on the airpack, the ones for the other trucks are downline. It's in the manuals... (unit maintenence I believe, but I've been looking at way to many of them in the last few days to be truly sure.)
