Two Questions
Loose Deuce
South MS.
Is it possible to get a new emergency air valve for the deuce, the hand valve at the glad hand coupling ? Mine doesn't work and I have it plugged off for now. I wanted to get an original type before I had to start modifying it. I may have to get a used one instead.
last question, anyone remember the size allen wrench thats used to remove the fuel tank drain plug ? I will figure it out eventually and I dont think I have a allen socket that size.
gringeltaube
Staff Member
2,479
Montevideo/Uruguay
Is the stem stuck frozen and the valve leaking? Don’t throw it away!
It takes a hammer and punch, a 13/16 wrench and some TLC to have it completely disassembled and cleaned. Eventually the coil spring is rusted and needs replacement.
Lubricate everything with silicon grease (also synth. grease) and it will work like new for years!
G.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Good info! Need to clean mine, pretty stiff. The one under the dash is the same, already cleaned/lubed it, and works good.
Barrman
1,730
Giddings, Texas
If you don't have a 9/16" allen wrench. Take a 3/8" bolt and nut which have 9/16" hex heads on them and weld them solid. Then stick the bolt in the tank and use a regular 9/16 wrench to turn it with the welded nut.
If you are in a hurry, a 3/8" bolt with a pair of vice grips works too.
FreightTrain
Banned
2,730
13
Gadsden,Al
hmmm,Mine was a 1/2 inch square drive(just stuck my ratchet on it and yanked!Also,it will more than likely be TIGHT!).........Like all the plugs for any fluid holding device on the truck except the oil pan drain plug!
