I have been told that the special grease is only used with the magnesium run flats, and isn't required for the rubber ones.Multiple YouTube videos on how to, as Craig points out above.
I prefer the engine cherry-picker method for removing the runflats, but there are compression tools AND the 2 bumper car method technique.
You need to compress and bend the runflat to insert it into your new tire.
You need to utilize a runflat to lock the tire to the rim, or the tire will not hold on to the bead on the rims.
I DO NOT RECOMMEND BEADLOCKS! Use runflats. If you blow out a tire you can roll over or blow up a differential without a runflat.
You must use special grease on the inside of you new tires when you use runflats! If you don't, friction might set your tire ablaze.
You need the correct "O" rings on hand prior to opening up your current split rims, so that you can close them back up later. I suggest you place the rings in the freezer for an hour to get them to tighten up and fit better. You need to identify your split rim version in order to order the correct "O" rings, as they vary in size by rim bolt pattern.
There is an art to placing "O" rings, and if you screw it up your rims will leak air.
Good luck.
T
You are correct, the manual does say to use "Lubricant, Runflat" with the rubber runflats (which is a different product than the grease used with the magnesium runflats)You were told wrong. Very wrong. You need the grease with all runflats.
Multiple posts on multiple forums about people who did not run grease and tires started smoking and also sustaining damage, because there was no lubricant b/t the run flat and the deflated tire.
YIKES!The ebay runflat compressor with the boat winch is absolute garbage. So I tried the youtube method with the hydraulic jack. Had about 6 tons of pressure on the jack making the runflat oval, when suddenly the runflat changed shape and launched the 4x4 timber spacer I was using out and it hit me between the eyes and now I have a huge scar there.
No I was trying to INSTALL the runflat. Pulling them out using the redneck pickup truck method is simple and easy.YIKES!
I was referring to maybe a different method where the jack and it's base are on top of the tire and a chain is placed around the runflat and it is pulled free. No wood timbers involved.
Coug, reread my post and didn't mean to sound so harsh.
I need to teach the 3 rope interlock method. I’ll try to make a video. Only rope. No wood.No I was trying to INSTALL the runflat. Pulling them out using the redneck pickup truck method is simple and easy.
Read a technical manual to understand "O" ring.Regarding the runflat again, I have found the goodyear original tires in very good shape, but i have asked in several tires shops here in Spain about to remove and insert the ru flats in the tires, and no body have done it before. So I need to know it is possible to install the tyres without the runflats?
Other question, somebody said that once oppening the wheel o ring should be replaced. What the hell is the o ring?
Thank you so much for the help!
Willie
