OK here's the deal.
I squirmed up under the Deuce with my trusty grease gun, gloves and a rag. Starting at the rear drive shaft, I gave it a good shake. It has a little play in it when you twist it, but no up and down play. Next was the shaft between the x-fer case and the middle axle. Same thing. The shaft between the x-fer case and the front may be a problem. I was able to twist it appx. 1 inch. No up and down play though. The short shaft between the transmission and the transfer case has me worried most of all. I can move it up and down a little where it goes inside the transmission. It doesn't seem to be any of the U-Joints, but where the yoke slides into the transmission on the shorty and the yoke going into the front axle.
Hope that makes sense.
I'm sitting here cringing. I bet I need some bearing work in the tranny and in the front diff (shudder).
I greased everything anyway, and it seems to have calmed the vibration down some but not completely.
![Hammer :hammer: :hammer:](https://www.steelsoldiers.com/images/smilies/smiley-hammer.gif)
