unable to edit posts
gringeltaube
Staff Member
2,275
Montevideo/Uruguay
Did something change where we can no longer edit/add to posts?
Nothing has changed to my knowledge but if you are referring to your "Challenge Coins"-thread in the "Conversations" forum, that is one of the few sub-forums where members cannot edit their posts.
There you said you "will add some, later". If this was your issue then just make a new post with attachments and I will merge it with your first one.
155mm
Chief and Indian
383
Guymon, OK
Ahhh, ok, makes sense, yes that is the thread and thank you. I will go add 2 more now, then I will be finished
155mm
Chief and Indian
383
Guymon, OK
Ok, that is all that I wish to add on the coin thread, if you dont mind merging those into 1 post please, and thank you again.
