ranchhopper
- 136
- 63
- south elgin illinois
I bought this 84 1009 from federal surplus on the GSA sight unseen looked pretty nice in the only pic they posted. I usually buy from federal surplus because the trucks come there directly from the DRMO and they are usually stock trucks. As I was trying to get the hood open while looking through the grille I thought I saw an A/C condenser after getting the hood open sure enough there was the A/C. Problem is they took off the DS alternator for room and disconnected the wires and taped them up I dont know if they left it 24 volt or not. They disconnected the positive cable that runs from the slave recepticle to the positive buss bar and removed the condenser from the PS alternator. The jumper that usually goes from the neg on the back battery to the pos on the front battery looked like they still had the batteries in series because of the size of the terminals smaller negative larger positive. It would have been nice if it had a set of batteries in it so I could have known what was going on. I bought it to resell because its rust free and the paint is still good but this has really got me stumped. The voltage gauge doesnt work but you would think it must have at one time given the effort put into reinstalling it next to the pushbutton switch for the glowplugs. I dont think one alternator can charge both batteries in a 24 volt system there is an extra wire coming off the neg on the rear battery one goes to the power block to the cab and the other goes to the positive buss bar I hooked up a set of batteries 24 volt in series and no start there is power to the large red wire going into the starter relay and when the key is turned to the start position there is power coming out the purple wire still no start.
