underpowered winch?
Capt.Marion
15
Atlanta, GA
If you want the full 13,000 lbs of truck weight applied to the winch line, you'd have to hang the truck from the ceiling by the winch, or get it on a literally vertical incline... mgsin(theta)
spicergear
Millerstown, PA
I also believe that the proper usage of the deuce winch on the truck for extracting itself states to have the truck in gear so that it has tires turning to help.
Kalashnikov
NH
Having been in the electric winch world first, I thought it was ridiculous to have an "underpowered" winch on a Deuce as well. BUT, you have over twice the amount of cable as most electric winches and a much faster speed as well. 15 FPM vs almost 4FPM on a Warn 12k on first layer. Overall it equals out I think. One block gets 20k and 100'+ from anchor when the electric would get you just 12k line pull at 100'.
Floridianson
2,503
Interlachen Fl.
Just a reminder you can carry extra pins but when the bumper is 2 feet under mud and water you won't be replacing it . Don't bust a pin when your the one that is stuck.
Also saw someone use a MV winch to pull someone out. There was still line out and they stoped the winch 20 feet short and used the truck in gear to pull the rest of the way useing the winch line. Do believe that would be a no no.
