- 4,411
- 3,928
- 113
- Near Austin, Texas
As stated above, the M101 trailer is an M116 chassis with a cargo bed. The trailer may have either M101 or M116 on the data plate.
And yes, the early ones were designed to operate with the M37 and use the same wheels/tires.
The manual you want is TM 9-2330-202-14&P
It is in the Trailer section of the TM (technical manuals) forum. Look here -
Cheers
TM's for Trailers
Listed below are a number of the TM's for various trailers. To save them to your computer, right click, select "save as". LO10-7360-206-12.pdf LO10-7360-206-12 MKT Lube Order. MWO-10-7360-206-30-1.pdf MWO-10-7360-206-30-1 MKT Modification work order as of May 1 1998. TB9-2300-280-30.pdf...
www.steelsoldiers.com
Cheers
