Jacksonville Searchlights
- 2
- 3
- Jacksonville FL
Yes they fit.Unimog Flu419. I want to upgrade my OE tires 12.5r20. Has anyone tried to put LMTV 20" tires on a Unimog? 395/85/r20?
No they do not rub.
Good luck getting them seated. Tried two blow tanks at the same time no go.
Used a mixture of either carb clean and brake clean. Make sure you put a flaming rag at the end of the stick. Make sure you remove your Schrader valve and put on a clamp on Air Chuck. Have a guy on the air hose to charge as soon as the tire seats. They do drop off very easy.
Rear tire is original tire 12.5r20 in second picture.
Installed 12.00r 20
