keefer
- 0
- 0
- gloucester/virginia
ok, so i havnt found much on fuel problems in the forum so im making a new thread.
heres the problem. my truck is periodically dying when i drive down the road. im definitly getting air in the fuel system somewhere because i can immediatley bleed a ton of air out of the bleeder on the fuel filter base. so far i have
-replaced the fuel pump with no luck
-bypassed the fuel filter to see if the leak is in the fuel filter base (dont worry i have another filter, cav style canister filter/fuel heater). no luck there either
I can bleed the air out usually and run it for a few miles before its sucking air again. anybody know
-how to properly bleed a cav style filter? it has one screw on the top that looks like its for bleeding and i tried it with some air coming out but doesnt seem to be nearly enough to purge the system
-places to look for leaks?
-how to tell if its the injection pump thats bad?
any help would be appreciated. this is my dailey driver. dont want to take the motorcycle 140 miles round trip each day. especially if it rains
