Unloading an M1082 - Caging Bolts and other unloading strategies
chucky
19,313
TN .
OK you should be fine for hooking up most guys go pick these things up with pickups that the hitch is to low to set the lunette down on the pintle cause of the landing gear wont crank down low enough to hitch up so thats why i push for the high lift jack for those guys ! Worse case you can take a shovel and dig a hole if on gravel or unpaved ground to drag the landing gear into the hole so you can latch up and unpin to pull the landing gear back to stow away and there are to electrical plugs for that trailer a military plug and a civilian plug you can get on amazon or ebay way cheaper than a truckstop !
