Unloading my new M35A3
greenjeepster
10
Southbury, CT
Unfortunately it sounds like you need to rebuild that Allison. Does it make noise when in drive, like a high pitch squeal, or is it completely silent?
Heavysteven
10
Hickory Flat Ga
I would double check everything on your truck to be on the safe side. There are parts missing blinkers, CTIS cover, and the door was swapped. Could have been a parts truck.
BKubu
1,149
Gaithersburg, MD
A transmission rebuild from Allison will set you back more than you paid for the entire truck! I know because I had the transmission in my M925A2 rebuilt by Allison. I would exhaust every possibility first.
Joaquin Suave
32
Alta & Baja California
There are many private rebuild houses for non-electronic Allisons around the country. Stay away from Allison when ever possible! I not sure about MT 654's, but rebuilt MT653's were selling for $1800.00 a year or so ago (with core).
You need to call THE ALLISON GURU!!!!!!!!
Ted Keating @ TKT Sales 267.716.7332
metexaco
Waxahachie, Texas
Truck looks extremely complete minus the lights. Someone just lifted them for their own truck probably. It has a brand new out of the box door that looks to have just been installed shortly before I bought it. There are 2 or 3 new tires on the truck and one that looks to have met up with a forklift blade. It is missing the spare. Sure starts and runs good! Hope the tranny is something simple to fix!!! Anyhow, it definetly hasn't been a parts truck.
abh3
Florala, Al
Check the ATF fluid behind the little door in the passenger footwell. Some have engine oil, some ATF, I probably wouldn't mix them.
Don't listen to the anti-A3 folk and their $10,000 trans rebuild stories, these are really common and simple transmissions, $2,000 rebuilt online and $500 used at your local truck salvage...
I love my A3 though the CTIS can be annoying at times. :p
metexaco
Waxahachie, Texas
Sounds real good!
Can the CTIS cause problems? Or how does it cause problems??
